DRZ 400S Low speed miss
Hello,
My 2003 DRZ400S is driving me crazy. It will have a low speed miss,approx 33-35 mph. At low speeds it jerks. I checked the valve clearance, pulled the carb off last week and thoroughly cleaned it. I moved my air screw out to approx 4 turns. Now it seems that it doesn't back pop as much when I come off the throttle, but still has that hesitation! It is still factory jetting on my carb. I would think that it shouldn't miss,even with factory jetting? Only thing I have done,was put the billet tip on the muffler.Any suggestions?
How is it at idle? My idle is a little rough since I went back to a stock plug. I guess I will have to go back with the hotter plug. You only notice the hesitation a certain speeds? or certain RPMs?
I notice it mainly at low speeds. It will stall once in a while on my way to work. Doesn't seem to stall on the way home though. It idles ok, once in a while a miss. It isn't smooth in 2nd or 3rd gear at approx 25ish mph. I can't figure it out, but I am quite sure it shouldn't be that way. My other bikes are smooth.
Have you carried out the air box mod too much??It done the same on mine but reduced the area involved an now its ok,just seems as if it was getting "too much " air through,im running standard carb with a remus slencer system
hope this helps :thumbsup:
I haven't done the air box mod. It is still stock, except for the billet tip.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
