XR200 Power Output?
If I remember correctly Powroll told us on their dyno a stock XR200R had about 12 HP. Our 218 stroker engine (torque cam) about 18-19 HP with peak HP coming in at about 8,600 RPM. You don't rev it nearly as hard as stock to get power, and WAY more bottom and mid. :thumbsup:
Old School Al
He asked about the torque too...I would be curious to know that number as well if anybody has the specs...
Anywhere from about 16-20HP (at the fly) would sound fairly accurate. For some reason it's incredibly hard to find the power output for alot of bikes (bar motocross) :thumbsup: Any ideas about the torque though? :lame:
11.51 lb-ft @7500 rpm (from " On the problem of the XR200 ")
http://www-staff.lboro.ac.uk/~elvpc/bikes.html?http://www-staff.lboro.ac.uk/~elvpc/papers/XR200.html
I run my 200 WFO 90% of the time (its a MX bike). Running 12/51 gearing it pulls well thru the sand in 3 or 4 th gear.
The tracks so rough its faster than most guys on their real MX bikes unless they are a good rider.
Old school - AL do you use a 5 or 6 speed gearbox ?
We run the 6 speed tranny as we run in the woods lots, with some mx thrown in to mix things up. Have had no tranny problems yet with this engine set up. If we put a dedicated mx XR200R together we would run a more radical engine and the five speed tranny though.
Old School Al
XR80 5 hp, XR100 6.5 hp, XR200 12.
Octain Booster ads 20% temporally
Old School Al
Please remember Powroll at high elevation so that number is conservative.  Stock XR200 more power than stock CRF230 but not as much as uncorked and jetted CRF230, which is ~18 RWHP.  My guess is that good XR200 is ~16 at sea level since it has higher CR and more cam than CRF230.
  • Similar Content
    • By Daniel627
      A while back I picked up a '95 XR250R swingarm that I plan on installing on my '90 XR200R in the near future, to save a little weight and have rear disk brakes.
      I missed out on a totally complete rear brake system for $75 a while back which sucks. I look on Ebay every now and then hoping to find a great deal on a complete or near complete setup but no luck lately.
      Is anyone aware if Honda used the same brake system that was used on the '90-'95 XR250R, on any other bikes?
      If so, then I can expand my search. If not, then I'll just keep looking at 250 parts til I find the right setup for the right price.
    • By riverside21
      Has anybody purchased/used one of these Arrowhead IHA6017 cdi boxes??  I tried 2 different ones of these on a 1987 and 1994 XR200R, and the bikes won't even start.  Bikes just pop and backfire, had to put the old cdi's back on.  I noticed when I ordered the boxes they stated "advance ignition curves" in the specs.  The box is also much bigger than the stocker and won't fit in the rubber mount.  I didn't mess with moving around the timing to try and get these to work....I just sent them back.
    • By riverside21
      Recently picked up a 1987 xr200r in pretty good condition, all stock.  The carb was all gummed up and running real rich, and the previous owner removed the baffle and end cap from the exhaust, but left the air box top chute in place.  I cleaned up the carb and verified all stock jetting, needle position, air screw, etc.  Where we live the quieter the better for off-roading so I ordered a new baffle and end cap, but did ride the bike for a week before the parts arrived.  With the muffler parts out I had a brown plug and plenty of power throughout the entire throttle range.  Got the muffler parts, installed them and now the bike falls flat while climbing hills and gradually rolling on the throttle, I get a burble at low speed sometimes and I have a black sooty plug.  I'm kind of at a loss on this one.  I realize that the parts restricted the exhaust....but it's basically back to stock and I've had these bikes stock before and they ran fine.  Seeing as I have all stock jets and am getting a sooty plug, I'm wondering if electrics are weak?  I also tried adjusting the air screw in/out and moving the needle clip to position 2, either of the two made my problem worse.
      Any ideas?
    • By riverside21
      So the other day I notice that the rear shock spring on our 1994 xr200r had cracked and separated about 2 coils from the top.  No big I thought....just go on Ebay and pick something.  Well, after a few days of looking I can't find ANYTHING used or aftermarket!  The stock Honda spring #52401-KT0-691 is "no longer available".  Can anybody lead me in the right direction to get a replacement spring for this bike??
      Thanks in advance.
    • By hondamaster1
      I have a 1999 xr200r. I used to ride it like a champ than i stored it for a year getting it out once in a while to run. Than i took it out a couple days ago started it and it ran and died instantly. I cleaned out the carb put everything back together and still sane thing. You have to feather the throttle to keep it running. It also made a loud pop and it jerks you when you ride it. I changed the spark plug, cleaned the carb, and put new gas in the tank. Any ideas? Wanted to ride it this weekend...
