Stage 1 or Stage 2
I am the proud new owner of an 07' DRZS and should have been a long time ago. I am getting ready to mod this thing up but before I do I want insure I get the right carb kit. Should I get the Stage 1 or the Stage 2 dynojet kit? From what I have researched here, I plan on this:
Running between 2000' - 5000' arid desert climate
3x3 cut
136 Main
25 Pilot
Kientech extended fuel screw between 1.5 - 3.0 turns
Open up the stock pipe. (because I like it LOUD!!!!!
I can't seem to find any single piece of information that specifies Stage 1 or Stage 2 for what I plan on doing.
Thanks...............
Stumble
To my knowledge there is no stage 2 dynojet kit. When you cut the 3x3 hole in your airbox you are basically creating the "burned" stage 2 kit.
Just purchase this dynojet kit:
http://shop.thumpertalk.com/ProductDetails.asp?ProductCode=PU%5F10070170&CartID=
a 25 pilot jet
and, I think a 155 main jet from the tt store.
Do another search on for "dynojet kit for the SM " to get the proper specifics for the main jet size. I have a S and jetted acordingly to that bike which is a bit different.
Hope this helps.
Stage 1 is putting the Dynojet needle in and adjusting the main jet for stock or aftermarket exhaust.
Stage 2 is the same as above (with different Main) but with a 3x3 mod
