• Announcements
    • Bryan Bosch
      Buy/Sell/Trade/Wanted   01/18/2018
      Checkout our robust classifieds for amazing deals on bikes, parts, accessories, gear & apparel
robklx400
DRZ pics, lets see your Z
11,528 posts in this topic
2013 before I took her out and single tracked she's a little more scratched up now !
5 people like this
Its been a while since I posted any pics of the SuperMoto. Ive done a few things.. Some you can see... Some you can't. lol.. Enjoy... And ride safe!! Hopefully warm weather is around the corner!
6 people like this
7 minutes ago, DRZadvKat01 said:
Awesome...thanks! They did a great job! Did you have input or did they have these pre designed?
Pre designd lol i wish i could get custom graphics
1 person likes this
On 2/11/2017 at 5:27 PM, BMSteve said:
Here's my DRZ, just got it a couple of months ago, 2102 model with 328 klm on the clock, originally came black but it's now white
Sorry there not the best photo's, I'll add better ones one the weather cools down a bit and I can get out and ride
Wrapped the shroud in white, didn't come in the white kit I got
I was going for the same look with mine. I wish I had your tank. Since this pic I've changed the seat to a seatconcepts and I've put on a Baja Designs KTM LED headlight in white. Also added a wolfman peak tailbag.
2000 DRZ400E:
8 people like this
Nice looking bike, you've obviously spent a lot of time doing it up, I like the look of those tyres as well, what brand/model are they
Cheers from across the ditch.
thanks BM. they are Continental SM Attacks. not great on wear but good feel.
Just traded my goldwing for this on Sunday. Needs a bit of work. Hard starting right now, he did have it running, but says it  is cold blooded. I know it sat since last summer, so I am thinking it might need a good carb cleaning or tank. Won't have a chance to really get into until this coming weekend. Suggestions for repair manuals?
Edited by kattotonic
typo
1 person likes this
My bike arrived!
All the MODS:
IMG_1246.JPGK&N filter
3x3 Mod
FCR 39mm Carb with mods
JD jetting kit
Exhaust - MRD Pro exhaust
Lighting - Full HID headlight with high beam
Tail light DCR with 12 o'clock lab lens blinkers integrated
Zeta hand guards with integrated blinkers
Front Suzuki Super Moto appearance package front end fender
Underbar mounted mirrors
SSW quick twist single cable throttle
EBC wave rotters and pads
Core steal braided break lines with gold tips
Thumper Talk - Case savers
DRC wide foot pegs with sliders
T Rexx axel sliders
Zetta Fold away leavers
Zetta Skid plate
Zetta chain guard
Zetta Heal guard
Zetta Rear rotter guard
Eibach front and rear suspension
Spokes wrapped black
powered coated triple tree, Bar risers, Ignition plate, Break master guard, Sub frame, rear swing arm
moto hose exhaust slider
9 people like this
My first ride (Moto Cove, VA) and now the top end is being under construction :D
5 people like this
My 2007 SM. Bought it last autumn and used the cold winter months here in Austria to give it a makeover. For now its finished, but as soon as I get more money I might buy some more mods ^_^
4 people like this
  • Similar Content
    • By Markl5557
      Morning ,
        I am looking for recommended radiator guards for my 2017 drz400 I was looking into the devol metal ones . Any one have suggested brands? Replies are always appreciated !
    • By Ted Lukecart
      Parting out a 98 KX250.  NOTE: bike is not complete so if you ask about "price for all" it will be based on each part and only a 10% discount plus freight shipping.
      Parts List:
      2- Engine cases with new bearings installed (right & left) $350
      1- Case gasket set (new) $25
      1- Crank w/rod (new unused) $150
      1- Transmission gear set $100
      1- Set of shift forks $50
      1- Shift drum $25
      1- Kick start input shaft/gear/spring $25
      1- Clutch disk set $75
      1- Clutch basket $50
      1- Clutch pressure plate $25
      1- Clutch lever and input shaft $15
      1- Fly wheel $50
      1- Stator w/wiring $100
      1- Wiring harness $50
      1- Coil w/wire $25
      1- re-plated cylinder (New unused plating)(NO power valve assembly) $350
      1- Top end gasket set (new unopened) $25
      1- power valve assembly $75
      1- Piston/rings/wrist pin (New in box) $85
      1- Cylinder head $50
      1- Kick starter $15
      1- Shifter $115
      1- Clutch cover $25
      1- Power valve cover $15
      1- Fly wheel cover $25
      1- Carburetor (assembled) $100
      1- FMF Gnarly pipe (plated)(no dents) $150
      1- FMF Power Core muffler $75
      1- air box (stock) $50
      2- Radiators w/cap $150
      1- Fuel tank (standard MX size) $100
      2- Forks (stock) $250
      1- Shock w/linkage (stock) $100
      1- Swing arm $75
      1- Frame w/pegs $150
      1- sub-frame $75
      1- Triple clamp $100
      1- Renthal handle bar w/mounts $50
      1- Hand throttle assembly w/cable $50
      1- Skid plate (aluminum)(no dents) $75
      1- Front brake caliper $50
      1- Front brake lever assembly w/hose $25
      1- Rear brake lever $15
      1- Rear brake slave cylinder w/hose $25
      1- Rear brake caliper $50
      1- Clutch lever assembly w/cable $25
      1- Front wheel w/brake disk (no tire or tube) $50
      1- Rear wheel with brake disk (no tire, tube or sprocket) $50
      1- Front fender (new unused black) $25
      1- Seat w/good aftermarket cover (black & green) $25
      All prices include shipping To Washington, Oregon, Idaho, Montana.  Outside the Northwest I will add additional shipping cost based on your address.
      Call or text for pictures
    • By Simon Davis
      So heres the issue, i have replaced the seals multiple times for the water pump however still get a leak out of the weep hole. Over time it goes into the oil side. I think ive found the issue but dont know how to fix it. There is grooves on the ‘water pump shaft’. To which most would say replace it, its not as easy as that, the shaft is directly connected to the crankshaft so my question is, can i fix these grooves without replacing the crankshaft and thus spliting the case?
    • By Michael Fry
      Hey guys.
      Im a bit of a noob when it comes to working on bike so be gentle haha. So I bought this bike a couple of weeks ago and it has fork covers on it and I didn’t think much of it. Upon later inspection it’s revealed that the forks have quite also of what looks like corrosion or rubbing on them?
      Should I be concerned? Will I need new outer tubes at some point?
      Im really stuck here as I’m yet to find any topics on forks that look like this. Any info on what I should do to get rid of or prevent further damage would be greatly appreciated. Cheers.
