DRZ axle nut size
What size wrench do I need for the front and rear axle nut on the drz400? Trying to take the rims off but dont have the right size. Im making a trip to buy it but I want to be sure. Thanks!
I'm pretty sure its a 22mm, and it should be in ur OEM toolkit!
I dont have that kit, I bought the bike used and I didnt get it. Thanks.
ahhh i see. Well if memory serves it is a 22mm. could be a 24mm as that is in the kit too. but im pretty sure its the 22mm:thumbsup:
Get out ya calipers :lol:
24 mm
Mine are 24mm. Can use a 1 inch socket as well but its a little sloppy.
24mm front and rear.
Thanks everybody, just got an adjustable wrench and got them off, installed Seal Savers and tomorrow Im getting Kenda 270's. Thanks!:lol:
If you don't have a 24mm, a 15/16" fits perfectly. I went to the local second hand store and picked up a nice long 15/16" box end wrench for $1.
Awesome thanks!
Sent from my LG-H918 using ThumperTalk mobile app
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
