?"Fuel leak"?
:lol: I have rescently noticed that when my 1987 DR 200 H is at an angle, or if I set it down fuel begins to pump out of the top of the motor very rapidly. I was wondering if someone could possibly tell me what this problem may be, and how I could fix it?????? :confused:
Check the float valve in the carb is my first guess.
Thats what I am thinking too if thats the problem how do I fix it ?
Remove the carb, open the float bowl, check the float valve bij lifting the float up and down while you have the fuel line connected to the tank.
Check as well if the float is leak. If it is chances are the float that is full of gas won't actually float and close the valve.
Good luck!
