yz125 suspension
i just got a 02 yz125 with pro circuit suspension and its dialed in at about 150-160 pounds. i weigh about 185. anyone have any tips for dialing in the suspension? coming from a crf150, im new to the nice suspension..
Your riding style will play into your suspension setup . A 180lb novice rider may have the same spring ratesas a 150 lb intermedate. start by setting ur sag , that seems to be in the 90-110mm range. then setting all the clickers to the factory settings and ride. play with the clickers a couple clicks at a time ,either soft or hard and see what suites you.
