glowing red exhaust
after idling my 07450f only for a few mins i notice the section of pipe coming straight from the head is glowing red hot..how normal is this?
its not ,richen that thing up or dont sit there with it idling it needs air to cool!
If you are leaving it on choke too long it will also raise exhaust temp. and check the adjustment on you hot start cable, if there is insufficient freeplay and the plunger is not closed all the way it could cause the bike to run lean which will raise combustion chamber and exhaust temps.
i had the same problem with mine . but it only happened the first time i rode it.
Geeeeez.......... This topic is getting as ridiculous as the "What's the best oil" threads!
Do a search....... or go ride. Did you see that there is no radiator fan?
