boyesen shokout grip system
the old Flex Grip system...you'll be surprised at the difference,in a good way! the only drawback is when it comes time for new grips,you'll have to purchase two sets because of the throttle tube diameter of the Flex Grip.It will help with a nagging wrist injury.Good luck.
Will they work with any brand grips, or do they have to be refitted with the Scott's?
(and if I'm understanding, they require throttle grips on both sides, correct?)
Yes,any grips will work,but 2 sets because of the diameter.Small price to pay for the benefits IMO.
It is like a throttle tube with a housing on the end. Inside the housing are little rubber dampers that cusion the movement of the grip. You can adjust how stiff it is with different dampers. You can make it stiff one way and soft the other. At the stiffest setting the grip doesn't really move at all unless you hit hard off of a jump. I like mine set up soft so it moves quite a bit when heading through whoops, easier on your hands that way.
I'll admit that I'm a little confused by the Boyesen page that's linked...from the pic of the product, it appears that this 'special' grip sleeve is only for the clutch side, and the throttle side is the regular application...am I missing something?
It is only for the clutch side since the throttle side already twists. The twisting motion is what makes it easier on your hands.
I thought it was the cushioning effect that relieved the vibration. I'm not sure both grips being able to twist would feel particularly safe.
Really. I had no idea that they were rotational...glad you posted that KJ, that sheds a whole new light on it.
I agree that the idea of the clutch side twisting seems unsafe, but it does not twist enough for you to notice while riding. I notice it most on rough sand tracks it just feels like my left wrist is not being hammered as hard with it.
the Flex Grip doesn't rotate,it moves maybe a couple of MM's at most fore and aft giving just enough to alleviate wrist issues...you will not notice the movement while riding but will notice the benefits after a days riding.Do not worry about the movement....
