crf450r coolant leaking..help!
so i have an 02 crf450r and it is leaking coolant out the weep hole whenever i run it. this happened once before and i replace the gasket, water pump, and bearings in the water pump and it has happened again. does anyone know why this is happening and what i can do to fix it becuase i can't ride it.
-mack
When was the last time you replaced the seals in your water pump? The seals on my 07 450 went out in about 15 hrs. I over heated it on a hill climb. Just order new seals and a gasket. Check out the bearings and shaft when you have it apart if they are bad replace them. Seals are cheap. And use Engine Ice.
Might just be because you let it sit to long.
If its only a drip or so I would ride it some more until it is a noticeable amount coming throught the hole. Then replace the pump seal.
yeah its noticable...plus i'm riding ice so if i let it sit and idle for a sec there is a little puddle in the snow
