98 Xj T-case
i busted my transfer case in my 98 cherokee and im riping out the busted one but im haveing a hard time geting to the six bolts that hold it to the trans. has anyone ever riped out a t-case im a cherokee. or know wut would make it easyer to get the job done
You need to get a jack under the transmission, remove the crossmember, and then lower the jack a bit, this will let everything angle down to give easier access to the bolts. Make sure you shift linkage is disconnect, and dont lower everything too much, so you dont ruin the engine mounts. Hope this helps.
