Crank installiation
Im ready to go back together after splitting my cases. The crank is a really tight fight going into the right side case. Any suggestions on how to easily get the crank to slide through the bearing without beating the you know what out of it. I know honda suggest a tool but guess what no one has it.
Hi, if you can get the crank back out of the left side easily enough, stick it in the freezer.
If not dont worry too much about it, heat the bearing up in the right hand case with a hot air gun, get it nice and hot. The crank will slip in pretty easily.
If you can put the crank in the freezer then it will make it even easier
Cheers.
