Tools needed to repair flat/remove wheels.
bike is stored away, but i'm ordering tools. what size wrenches do i need to fix a flat tire on the trail?
thanks!
This is what I use:
24 mm wrench for rear axle nut (rider wrench)
12 mm wrench for rim lock
Valve stem wrench (I use valve caps that have one)
2 tire irons
Small vice grips to hold bead on remount
Patch kit
Spare tube (a front will work in the back in a pinch)
CO2 cartridges and cracker.
Saw a neat trick a couple years ago. You can patch a tube without taking th e wheel off. Haven't tried it yet though.
