RPM settings for Vapor ?
I have a new 2004 DRZ400E. It did not come with a tach. I've installed a Vapor. I want to set the "RPM Shift Indicator" value and the "Over Shift Indicator" value on the Vapor.
But, my manual doesn't list any RPM info. I've searched this site and couldn't find it either. (Maybe I'm using the wrong search criteria? :censored: )
What is the redline for an E model?
Thanks
11K for an E, 10K for an S or SM, Well that is when the rev limiter kicks in. Power drops off before that. Do a search here for Dyno graphs that appear to match your setup (pipe/carb, other engine mods) and use the graphs to set the points.
Thanks for correcting me, auto. That means an S limit is 500 less, or 10,000RPM. I was half right. Having the indicators 'show' at peak torque and HP is more important than max RPM as the limiter will let you know that. you want to be be in that sweet spot.
well, i guess that those medicines of yours are still in your system :censored:
