bearing size in linkage and swingarm??
are the bearings in the linkage the same size as the bearings in the swingarm? except for the part on the L part of the linkage that the bearing is bigger. o yea and are the seals the same too? this is an 02 by the way. thanks.
I greased it lately but i didn't check the size. If You don't want to take out everything You can check in OEM parts cataloque, if all the bearing and seals have the same numbers ,that means they are the same,if not...probably different. I've just checked it for You:) The answer is no, the numbers are diferent so I'm almost sure that the bearings in the swingarm are bigger than one in the linkage
