drc flasher/dimmer/horn switch install
Anybody done this one? I just got one today cause I wanted the ability to shut off the headlight. It didn't come with a wiring diagram and the wire colors are different from oem. From the stock switch there are 2 yellow wires, 1 white & 1 blk/white to the headlight. Which one is pos? There is another yellow/white wire seperate from the 6 pin plug that cuts out the headlight when unplugged, what's that all about? Can you tell I'm electrically challenged? I meant to put this on the drz-400 forum, sorry!
