05 KX250 float height and carb removal
What's the prefered float height on an 05 KX250? I've got a service manual on order but would like to take a look at the jetting and float height this weekend.
Also whats the best way to get the carb out? I took it out from the left side but looking back it seems like it would be easier to remove the header and take it out the right side.
Pull off the subframe and airbox and take it out the left side of the bike opposite the exhaust side.
2005 KX250 Float Height is 6.5mm plus or minus 1.0mm (.256in plus or minus 0.039in).
Float height is measured from the from the bowl mating surface to the highest point on the plastic float.
