New Throttle Cables, Bog Developed
Hello All,
I have an 04 that has never had the slightest bog. I replaced the throttle cables and throttle tube and now it bogs down when I snap the throttle open. Could this be related to the new cables being incorrectly adjusted?
Thank you for the help.
Zazoos
You said that you replaced the throttle tube, by any chance did you get an aftermarket one, and not the stock honda one... b/c an afermarket throttle tube could have a different twist rate (dont know what its called)... Basically you twist the throttle a shorter distance than the stock one, and if you are doing it at the same speed, that means that you are opening the throttle faster than you normally would have, and that would explain the bog.
Yes, I replaced it with a Titax Aftermarket Tube.
I will put the stock one back on and check it out. Any chance the cable adjustment would contribute to the problem?
Thanks
Zazoos
