Fork sub tanks
Anyone running fork sub tanks? Enzo or Aircell
http://www.aircellracing.com/
I found some old posts from a few years ago but not much detail.
What exactly are they providing? I think they're acting as a additional volume for air compression with a metering valve to control the compression rate.
If that is wrong could someone set me straight?
Also, My YZ is primarily for offroad racing but I like to MX for practice. Could sub tanks be an alternative to revalving between the two riding styles? From a weight perspective the spring rates are correct.
Thanks.
I dont know how well subtanks work on the new style yz forks. They were great on my 97. I really liked having them. Think of them as a way to alter the oil volume in the forks..without touching the oil volume. It was the perfect set-up for trail riding one week, and track riding the next.
Still, the 06 forks worked so much better, I never bothered adding them back in.
I have a set of FVO sub-tanks that I experimented with on my 07 YZ 250. They do work nice for the woods if you have stock valving. However, I don't reccommend them if you plan on revalving in the future. YZ forks are pretty good right from the factory, a revalve makes them perfect. Sub-tanks are over priced. Hey, I will sell you mine though pretty cheap!
Mark
Trash - It sound like the subs are a alternative though not as good as a revalve. Is that correct?
If so and I can keep the stock valving it sounds like the way to go.
If you serious about selling yours, PM me with what your asking for them.
Thanks
http://www.aircellracing.com/Also, My YZ is primarily for offroad racing but I like to MX for practice. Could sub tanks be an alternative to revalving between the two riding styles? From a weight perspective the spring rates are correct. Thanks.
From the discussions I've had w/Ross at ENZO, the '06-'07's don't benefit greatly from subtanks. I would tend to believe him as he is in the business to sell products/services.
Anyways, if you're riding offroad and mx a good compromise my be the Factory Connection GNCC valving. I'm considering this route for my '07 as I plan to do a bit of both if the ice ever melts. I had a chance to ride a friends (AA HS guy) '06 with the FC setup and it was very plush, yet worked well on the mx track. A little plusher than I'm used to, but at 41 I'm steering clear of SX style terrain and tracks anyways. I also read that Ty Davis has a very good setup through Race Tech that works pretty well for both types of riding.
I will post a ride report when/if I get it done.
Did he specify MX, SX, offroad, or all of the above? I tend to do pretty long ride days and find myself bleeding the air off quite a few times throughout to keep the front end working decently.
I haven't had a chance yet to abuse the new FC revalve on my YZ, so I can't say whether it's better or not. But in stock form and in my first revalve, I feel I could have benefitted from sub tanks.
I was speaking to him w/regard to MX more than off road. However, from a technical standpoint (he was def speaking above my head!) it sounded like the subtanks weren't as much of a necessity for the newer KYB's.
Let us know how the FC revalve works. Did you get the offroad/GNCC setup?
I had them set me up for 160lb 'A' enduro, which entailed softer pressure springs and minor changes to the stock valving. I told them some of the enduro courses were almost hare scrambles, so it might be like the GNCC setup.
On my '07 YZF the stock suspension is awesome- better than the stock '06 yz. I'm using it for scrambles and CC which are only a couple hours and it's only the last lap or so that I notice the front end stiffening up.
I don't really notice any changes in fork feel in a 5-10 lap moto or practice day at the track, so I could see his point there.
