lost key for 06' crf 150
Many moons ago, I lost a Honda key, and the solution was to get the number that is stamped onto the key assembly and take that to Honda where they can cut new keys.
I can't remember if I got a little metal tab with my keys like you get with a new car. That code can get you a new key made as well.
--Joel
i have misplaced my 2006 crf 150 key and was wondering if anyone could help me fix this problem
Not sure if that will work with an 06 150f. There is a drain somewhere, you have to turn off the key whenever your not riding it. With that mod, it wouldn't bypass the drain anyways, so your battery will be dead all the time.
True enough.
eyah the only easy way would be to find that stamp and get new ones made from honda
where would the stamp be located to get a replacement key?
Call your Honda dealer and ask them to be sure, but I think there should be a number code stamped into the key assembly. Remove that and take a look. If there is a code, take that to the dealer, and they can cut you new keys from the code. There are only some many key combos for each key blank.
That is how it worked for my old Honda Ascot 500.
--Joel
