Can you ID these carb parts?
So I opened the carb bowl up and found the below under the cap:
(Hopefully photobucket will work)
Can you identify the parts pictured here? I'm wondering what that plastic attachment(5) is... Also.. there is a screw inside a tube (4). Is this the fuel / mixture screw that gets replaced with the ez-adjust version? There is also a brass looking plug.. (6) what the heck is that?
I'm always hearing about the "clip"... where is that located? And when counting... such as 3rd clip position.. what end do you count from?
Thanks..
