Reeds
Will Power Reeds Mess Up Your Motor Or Take The Life Away I Was Going To Bye Them And Some One Told Me I Would Fry My Piston And Ring More Faster I Would Not Get All The Life Out Of Them Because The Motor Would Be Runing Harder
What bike do you have? That is not entirley true about the life of the motor. If you keep up on regular matinance on the bike you shouldnt have any problems.
It shoudltn affect you at all. Do you mean parts wearing out normally, or they wear out with ur right hand? Now you can wear your motor out VERY fast if you put reeds in that allow over rev. Reeds shouldnt affect you its how you use the bike. What reeds did you have in mind?
I Was Looking Justfor A Boost I Like To Hillclime Trial Ride Jump Ramps Some Time If U Could Let Me No The Best Reeds I Sould Get That Would Be Great I Dont Want To Replace My Piston And Rings All The Time I Just Want A Boost Thanxs
If you want a boost id look into a pipe and silencer, that would make your motor last as long as if you left it stock. you would get more power with a good exhuast then you would with a set of reeds. Now what you could do for a bit more power if you still want reeds is look into a Vforce set of reeds or a rad valve. If you dont want any of those look into a stock cage set of high quality reeds. I use the FMF torque reeds and they do me just fine ,but Im lookin for a rad valve to pickup the top end alot.
I HAVE A FMF FATTY PIPE WITH A FMF SHORTY MUFFLER ITS SUPER FAST BUT I WAS JUST TRYING TO PUT A LITTEL MORE KICK INTO IT BUT NOT TO MUCH DO U NO ANY THING ABOUT Spark Arrestor WHAT THEY ARE AND WHAT DO THEY DO AND IF I CAN PUT ONE ON MY SHORTY
I dont think your short fmf has a spark arrestor and no, they dont add power. Those are used for areas that require them to stop sparks from exiting the pipe to prevent fires. If anything they take away power. could you put up the year of your bike. The reeds will help you, and they will make that pipe work better. An engine is essentially an air pump. The better air goes out, the better you have to make air come in.
THANKS FOR TELLING ME WHAT A Spark Arrestor WAS I BEEN WOUNDRING I HAVE A 2002 CR80 AND I A LITTLE TO OLD TO BE RIDEING A 80 BUT I HAVE ONE SO I WOULD LIKE TO MAKE IT SIT HIGHER DO U THINK I COULD PUT 125 REAR SHOCK ON IT AND JUST RAISE THE FROUNT YA I HTINK I WILL JUST GO WITH THE REEDS GO FOR V3REEDS THEY ARE NOT MENT FOR RACEING RIGHT
Yea no problem. I dont know about the shock. Thanks to the year there is a part that will increase your power a bit. Heres the link.
http://www.rockymountainatv.com/typeDetail.do?navTitle=Intake%2FFuel&allVehParts=true&webCatId=16&webTypeId=80&navType=type
that site will give you options for reeds and I recomend the Air power blades. That will snap open alot faster and flow alot more air into your engine which means more power! The Vforce reeds are ment for racing but you can do what you want with them. If you wanted alot more power, the throttle blade and the vforce reeds would be a good choice. You will make a bunch more power.
ya i been looking at hcr powerblade they say increase of low end throttle response if i put this in will i feel much of any thing or not worth buying they have one called power now system..to i think there the same thogh
Yes you should feel the difference. I think they are the same but they are a little bit different. Now if you decide to just change the reeds you will have to tune the carb a little bit. But the reeds and the power now or the blades will help you alot through out the power band.
alsome i just will go with them 2 do u know if them quick shot accelerator pump covers work and how sorry about all the qestions
Yea, no problem. Also these mods will get you VERY noticeable power gains but face it. A cr80 wont make power like a 125 or a 250. so just keep that in mind. The Quick Shot Accelerator Pump Cover is for 4 strokes I think. How it works is when you twist the throttle open it shoots fuel in so it feeds more fuel into the motor to give you more power. The stock unit only has 1 hole in it to pass fuel the Quick Shot Accelerator Pump Cover has 2. So more fuel means more power.
oo ok well thanxs alot if i have any more questions i will wright back well thanxs alot help me big time do u know where i can get a over sized shifter and rear breake at
I'd just go to your local honda dealer and ask them because I dont know. Im sure they arent much but they would know. Ok right back if you need anything or send me a private message. later
