Hot start lever
Just bought an 05 and it still has the hot start at the carb. I have DID one on my crf that puts it up on the throttle side, but i cant find one for my RMZ that puts it on that side. Any ideas?
Will the '07 lever and assembly fit if so get the parts for a '07 from suzuki. Might be pricey but it works nice on my '07.
what side is it on, the clutch or the throttle?
Clutch side, its a lever mounted to the bar then a cable runs to the carb, that's it.
yeah DRD makes one that mounts under the front brake mount. It is about 100 bucks. I like it better on that side, then im not grabbin for throttle as im starting it hot.
be careful about the lenght of cabling, i bought one from crf, and it is short, but due to a couple of riser i mounted on handlebar, so i'm thinking to put it near the tank.
I bought the cable and plunger from an 05 RMZ 250 and if worked fine, you can use it with any clutch perch that comes with the hot start.
