Changing Fluids
On twin chamber forks (07 YZ450) if you change the fluid in the outer chamber, should you also change the inner chamber?
I just figure if you've got the fluid drained and the forks off, you're only taking the rebound adjuster off to get to the inner chamber so you might as well at least check the inner chamber for smooth movement. And if the dampening rod extends all the way out ofter being fully compressed.
So I guess what I'm trying to say is, you might as well. It never hurts but you don't have to.
