07 exc fuel cap after smog removal
What have you people been doing with your fuel caps after removing all the smog hupla off the 07 exc's? Do you replace it or cut the hose? Photos and web sights are great. Any suggetions.?
you can just run it to the right side frame spot where you took off one of the other hoses, I just got one of those lil hose deals that you cut to about 2-3 in and has the lil cap on it.
I ran mine to the 90 degree fitting on the right side of the frame. Thats where they come already attached on the pre 07s. Then I removed the ball from the gas cap, and no check valve in the hose either.
