CR250 rebuild
im doin my kx125 n it cost 400 for piston, complete crank, main bearings, complete gasket kit, complete oil seal kit and tranny oil. now add some dealer fees for splitting the cases and whatever else you will need them to do. add hours of your time too! i assume the parts for your bike would be a bit more mayabey like 500....? you could just rebuild your crank w/ a connecting rod kit instead of complete crank but it won't save you much dough.....for me it woulda only saved 30 bux! its probly more for you though since your complete crank is bigger therefore more costly....use www.midwestactioncycle.com for your crank + bearings. if your want to do a crank rebuild instead use www.lukesracing.com to rebuild it
Figure aroung 4 bills for parts and 200 - 250 for labor. If everything else is ok ( ie:clutch, shift forks , gears etc.)
