Year Model Help please.
Wonder if anyone can please help me. I am trying to find out what year my daughters CR125 is. I tried my Honda dealer, but soon as they find out the bike is an import, they loose interest in helping you.
Frame # JE01-1800111
Engine # JE01E 1800126
Thanks.
i am almost 100% certain that it is a 96...i might be a 97, but the shroud graphics are def. 96...:applause:
Be careful the 95 had those exact same shrouds
the 95's had red side panels though, and the shrouds were purple...
Plastics dont mean much as they are replacable.
The fork bearing head usually has the year clearly stamped. IE: behind the front number plate.
Thanks.
Probably because of the different continents, but I'm not showing any sequences that are close to matching the second series of numbers in the info that I have. Try a google search on VIN/serial #'s....
Below is the information on the back of the number plate. Verdicts Please ?
61136-KZ3M-6000
PLATE P NUMBER
1 2 3 4 5 6 7 8 9 10 11 12
94 . . .
95
96
97
HONDA
>PP<
Note: The dots are actually under 6,7 & 8.
I will check behind the platic number board tonight. Just to clarify: Is this on the steering neck, where the steering bearings are housed? Will it be a straight forward number stamped there like 1996 or 1997 ?
Thanks.
its a 96...
Kuritaro, are these numbers done in a different sequence depending on the original country the bikes are shipped to from the factory?
yes. each production run for each specific region gets its own numbering. my bikes never showed up on any vin searches in the states or europe...
61136-KZ3M-6000
PLATE P NUMBER
94 . . .
95
96
97
HONDA
>PP<
those are just the casting numbers on the plastic...
