will it fit (Hydrulic Clutch) ?
found it in my garage (used it on my CR500 but decided to use the "Easy Clutch" instead a few years ago), do you think it will fit the DRZ? has anyone got a pic of an engine with hydraulic clutch?
It does fit the DRZ but there are different slave cylinders and I do not know if the one you have will work. I think the slave that is used on the Yamaha Banshee is the one that definitely works. Could do a seach for Magua Clutch Jacks and get a confirmation.
I am in the process of installing this on my SM. I am making a special bar mount (don't ask) for the lever so it will be a while longer before mine goes on. I think Eddie has this setup on his bike.
yes it should fit. I have a Hydro clutch on my bike. What I would suggest is get another clutch arm cause you will need to drill it to fit. So if you get another to drill, you can keep your stock clutch set up just in case. Also you will need to fab a mounting plate to mount the slave to the motor.:applause:
