Drz400sm jetting revisited
Hey guys, I ve read alot of the threads on jetting the SM, i have the full Yosh, 3x3 mod, and jet kit . I ve bumped up the pilot jet 2 sizes, messed with the air screw, changed the main and still have Popping on Deceleration. Any of you guys have any other ideas? I ve also moved the clip position several times.....HELP PLEASE:cry: LOL
a slight pop on decel is normal.
Eddie its a constant pop, pops all the way down the rev range until just above idle..It sounds pretty bad...
vacuum line connected to the petcock?
I ll check, just to make sure where does the other end of the vacuum line connect too. I think i remember it might have been disconnected from the other end
So what is your current jetting then and what jet kit did you use?
