JD Kit Leak Jet (YZ250F)
Hey guys, just bought a 2006 YZ250F LE and decided to try out the JD jet kit, as I get a sputter at only ONE throttle opening. If I move the throttle slightly, the sputter goes away. Tried the TPS with no luck.
I have not installed the kit yet, but reading over the instructions about the o-ring, it's not clear at all. What leak jet does JD instruct to use? IIRC, not every bike comes with the same leak jet from factory.
Also, the bike I bought came with a Boysen Quickshot (I know, garbage). The AP only deals with bogging and whacking the throttle, which it does not have. Should install the o-ring or just leave it be?
just for refrence:
I am at about 200ft above sea level
Ride anywhere from 60-90 degrees
Not too humid in the hot weather, can be humid in the cold weather
Bike mods only consist of a PMB endcap (soon to be full Dr. D system)
I plan to:
185 Main Jet
JD Blue needle at 4th clip (Should this be 5?)
Stock 42 Pilot Jet
What about the Leak Jet and QS?
Thanks guys.
-Phill
Bike currently has the stock needle, was at 3rd clip, ran a tad bit better on 4th clip.
42 pilot leaves me at a 1.5 turn out and it's not too lean or rich. A 45 would seem too rich.
My question is not about the needle and such to run, but moreover the o-ring and ap and what to do with the jetting kit...
I suspect the Quick Bog can be tuned to work but I would have to have the carb in hand to know what its doing. I would recomend you get a stock cover so you can compare settings with others
But what about:
What leak jet does JD specify for use with thier kit?
250F's seem to work well with a #70 leak jet when also using the o-ring/AP mod.
Thank you. I'm assuming the thicker o-ring for motocross, and a thinner o-ring for trail riding?
Update. Just installed the kit. Ran the 4th clip posistion instead of the 5 and it's dialed. The 185 is much too rich though, maybe a 182 or 180 would do it.
72 degrees, 51% humidity, and half dirty air filter.
Just left the quickshot, but did not isntall the o-ring. Works just fine with the 60 leak jet.
Thanks guys.
