have any of you had problems with the sst...?
not fitting properly with a turbine core !! on a kx250? we just got my dad one for his birthday and its not fitting right.:applause: :applause:
Did you order the SST turbine core?? I have never had a problem, but you need a turbine core specifically for an SST pipe.
Dave
there are 2 dif. types of turbine cores? bisides the first genereation and the second?
i told you in your last post it will only work with the SST silencer bro.......do a search
yah but they dont have a silencer called the "SST Silencer". the other buy said he has a turbine core and it worked. the only problem is the scilencer piece that connects with the pipe is too long so we r just going to cut it down.
Yes there are 2 different turbine cores, there is a silencer for all the FMF pipes except for the SST, and one for the SST. The bad news for you is, FMF does not offer an SST turbine core anymore for a 98. They do offer the silencer for a 99, but it may fit a bit different.
See www.fmfracing.com
Dave
