I need some tips!!!!
Run a gear higher than what you think you should be in, that way you can just keep it pinned without getting wheelspin and you dont run out of power halfway through the section. Then grip the bike with your knees and try and keep everything straight and dont let your front end drop...thats a big no no.
First just always be in a gear that keeps your bike pulling so it keeps the front end up. If your not in a gear thats pulling your front end will drop and you will crash. Keep your knees squeezed up against your bike so you dont swap ends.
keep your weight over the rear wheel, with steady throttle in a high gear
