tricks to rear wheel bearing removal?
Hello, have a xr250 and I can't get the sprocket side cover dealy off.
The thing with 4 little holes. How does this come off?
Thanks
Not sure what the tool is called. But it is 2 pieces of metal held in place in the center and pivots. At each end is a piece of metal dowel.
Two of the dowels go into the opposite holes and you just turn it and the cap threads right off.
Hope I didn't lose ya.
It threads out.
Here are some tool options:
1) Get the adjustable type wrench Zappa described from Honda.
2)Buy a socket type wrench like this
"MOTION PRO HONDA REAR WHEEL BEARING RETAINER TOOL Easily removes Honda CR, and XR rear wheel bearing retainer rings without damaging your hub.$34.95 "
3) Use a hammer and punch. You be the judge on this.
OK now I understand. thanks very much for the help guys!!:applause:
I used a key for taking grinder discs off. Was a bit of a pain but finnaly came loose:ride:
Good job. I'll have to keep that one in mind.
