kickstarter shaft + gear q's
Hey guys,
I just put in a new clutch basket and plates and in doing so accidentally jarred the kickstart shaft, gear and spring out of its location. I reassembled according to the service manual and put the basket in and buttoned up the crankcase cover.
When I went to fire it up, I definitley reinstalled something wrong. The kickstarter has a lot of play in the forward direction and no movement in the correct direction. Anybody made this mistake before and know what I did wrong?
Thanks for the help fellas!:applause:
I put mine back together once and my kickstarter rotated too far forward and wouldn't tuck into its proper place. There are marks on the gears that needed to be lined up. It sounds like you might have something else going on if you cant kick it back at all. Take it apart and put it back together.
