weird jetting issue
OK, i bought a 2003 CR250 used and i just got to get the bike hot today.
There is spooge dripping out the silencer and the stinger onto the swingarm.
when i rode the bike it was running really lean. it was knocking. i gave it half choke and the knock went away, so im pretty sure its jetting.
off idle there isnt much power at all. like, no power.
i didnt get t revved way up, so im not sure how the main jet is.
so, im thinking the pilot is really rich, and i need to drop the clip a notch. does that sound right? it smokes a lot at idle too.
mix is 40:1
the guy i bought it from said the ain was lean too because he rides high elevation.
the bike has a FMF gnarly pipe on it, other than that it's stock.
i will pull the carb tonight and post some #'s and check the filter.
anything else?
thanks
Dave
The main jet is a 410, and the pilot says 27.5 on it.
the air screw is 1 1/8 turns out
its on the FIRST!!:applause: clip. i think i found my problem.
you think i should put it on the 2nd or 3rd clip? that carb isnt the most fun to put in/out.
