maybe the end of the o-ring mod for FCR carbs?
I think the old FCR (slant body) was better. I have this carb and instead of the taffy mod I just had to carefully open up the stops to adjust the AP. :applause:
i dont like making the solid connection.that just like wiring it.it puts some stress on the linkage.
Are you saying the linkage is not robust enough to handle a direct connection? Is it because of the AP arm spring?
Flex to accomodate the AP plunger/linkage bottoming out before actual WOT?
exactly.
Is this mod safe at all then? If you have a shortened AP travel via collar or big rivet diaphram, there's going to be a lot of stretch there.
