WIll This Set Up Work?
Hey guys... Well after a lot of thinking this is what I am going with.. Guess it is better off being patient and doing everything properly..
I know everyone has their own opinion and it depends on riding etc, I am just asking if there are any compatibility issues with this set up.. any problems during assembly I should consider?
Bike = 05' 250X
05' X Head, SS Kibble white Valves and springs
04'R Cam (Bought Accidentally through E-bay Want to try it out)
Je Piston Standard Bore 13.5:1 Compression (will be running 94 Octane Pump Fuel)
05' X Cylinder (Will Measure it and Hone it)
Add Engine Ice Coolant After
Manual Cam Chain Tensioner, How Often do you guys replace Cam Chain? Every Season?
It'll work fine. Just have the valve seats cut, and check the guides for wear before you install the valve train. You should get great performance out of that setup. It wouldn't hurt to add a new cam chain while your in it. It's something that you won't have to worry about later. I doubt that you'll have to replace the chain until it needs a top end again.
