2002 DR400Z water pump leak
I found the thread! Sorry.
Hi,
Have a big leak from around the water pump under the casing on the right front of the engine. I recall others have had this problem but don't remember what the fix was. It even leaks coolant when the engine is not running.
I took the small out case off and replaced the O ring but that did nothing.
Thanks for any help!
Doug
