07 WR stator/flywheel on 06 YZ
I'm still looking for options for hooking up lights on my 06 YZ250f. Would this work?
I'm not sure if that would work or not. The stator is on the engine cases behind the flywheel on a YZ. ON a WR it's on the ignition side case and the flywheel is on the inside (along with the electric start one way clutch). The ignition side cover is VERY different between the YZ and the WR (as is the main engine cases).
I'd look at E-Line for a conversion kit. I know they used to make lighting kits for MX bikes, hopefully they still do.
I called them a couple days ago and gave him my name/number.
Looks like that's the direction I'll be headed then. Thanks
