Tranny Oil Level
I have a 97 CR125 and I don't I want to make sure my tranny oil level is right. I can't find anything to check it with like a look through window or a dipstick. Do I just fill it all the way to the top??
there should be a check bolt on the right side of the motor in front of the clutch cover behind the water pump, remove it and fill it up until oil seeps out of the hole. or just measure your oil before you put it in, if you have a service manual or owners manual it should give you the amount
yep, the quickest way is the use the check bolt it should just barely trickle out it should not gush out. and whatever you do do not ever fill it up all the way full, it will suck the tranny oil into the cylinder and fould plugs and cause it to run weird i know from experience:prof:
