valve question
how many times can you adjust the valves before they are too far out of spec, and what happens wen they are this out of spec?, im askin for my freind, so dont be like, you have a two stroke, but thanks for the replies
As long as you can shim with factory shims, you should be OK. If they continue to change over a short period, the're probably toast.
