450 xc 06 vs. 07
what are the differences between the 06 and 07 450 xc ?
im a 160 lb. c class rider... would you perfer a xc or a xc-w?
i found a good deal on a 450, but idk if i could handle it in a 2 hour hare scramble. thinking the 250 would be better.
will the 08 450xc get the same engine the 07 450sx did?
As far as the engine & such the clutch cover was changed in 07 to a design that allows you to service the clutch without removing the main side case.
Suspension seams to improve each year. I would say get the best you can afford, nothing wrong with 06
i have a 07' and there is not much difference to last years. the only thing they really changed was the brake disks, and little in the forks. i used to ride a xc-w and i think the xc is better all around.
