white bros. carb kit.
Has anyone purchased the wht. bros. 38mm. carb kit. for the '06-'07 crf250 if so, how difficult was the installation process, and what was gainned by the kit. would you recommend the kit? I'm considering on installing one for my steed...
if you have an 07 the bog is fixed, if you get bog on hard landings all you need to do is remove the float bowl baffle. If you have an 06, I would try the complete redbeard AP mod first. download the pdf, sticky in the 450r forum I think. If the redbeard mod doesn't work as well as you want it to, then I would get the white bros carb kit...
