youngswerth if your around i have prob with your clutch
I found the problem as to not going into neutral its a clearance issue . ok ive narrowed it down it seems to be the tourque on the center bolt if to tight will bind up with either one either stock or aftermarket basket will do this . I dont have my manual handy does anyone know the tourque spec for this nut thanks.
problem fixed now it was the clutch hub nut torque . strange i guess this is a honda thing as when you tighten the nut up a little more to align the bending shim that little extra is just enough to cause it to bind . clutch works great now and bike goes into neutral no problem . Hopefully others will learn from this as I did .
