drz400e bogs heavly off idle
the bog finally threw me, the bike died over a small jump and a small throttle blip (it dies completely from idle to 1/2 throttle) i have to be careful HELP ME PLEASE.....abe
160 main, 148 pilot, 4 turns on idle mix screw, needle 4 from top stock exhaust and uni air filter
is there an adjustmet for acellerator pump (the only thing i have seen is a slotted bar that you bend with a screw driver but i don't think the shot is big enough
i just ordered an exhaust from muzzy might need a richer pilot and main won,t know untill installed got to get this bog under controll!
you riding the bike while testing correct?
does the pump squirt?how long?when does it start?
the needle needs to be on clip 5 and the fuel cant be out that far or it will fall out.
the pump squirts as soon as i touch the throttle its a good long squirt about how long should it squirt? pretty sure its 4 out its a very fine thread it needs a fatter pilot in winter its been really cold but getting warmer in bid D 700 ft above (do you think its a acellerator pump concern???)
