Leak in left radiator...???
I'm not sure if i have a leak in my radiator, every so often i look in the left radiator and the coolant is down to the bottom of it, but then i fill it back up. i don't see any leaks on the ground by the bike. another thing is when im running the bike and it gets up to the proper temp, i will see a little bit of steam coming off the radiator, could just be the snow melting on it, its snowing where i live, lol. but when the bike moves there is no more steam or anything. need help, thanks
if you are not moving the bike will overheat and some coolant will come out.
Also if you are going to slow try to use some of the recomended coolants here in the forums they do work. You can also try to put a fan if you just cant move.
