2005 TE510 Rear Suspension Damage
Just checked my rear suspension and found the lower shock mount bearing was loose. Took the whole thing apart and saw this damge to the link. Not sure how it happened but must be from the lower shock mount bolt.:applause:
Might be from a hard landing and bottom out with bad bearings.
The bearing that the shock mounts to is toast but the rest seem okay.
Has anyone else seen this?:applause:
I'm thinking about dressing it down so there are not sharp edges and putting it back together.
Yup, sure enough. Just re-assembled and the end of the bolt matches the mark in the link exactly. Flip it over and the bolt clears on both sides.
