04 yz250f Frame Question
I have an 04' yz250f and the frame paint is wearing off from my boots and it is getting rusty. Does anyone have any recommendtations I can do?
Frame Guards can be as cheap as ~$20 if you go with the plastic Acerbis/UFO ones. Carbon Fiber ones can get pricey. Check the ThumperTalk Store!
Also, you could just get the rust out with fine grit sand paper, seal it with a clear coat (spray on type) and just cover it up with the frame guards. Depends on how high the markings on the frame go. Look in my garage, if you look carefully, I have the Acerbis ones on that YZ125.
Sand it clean, primer it and repaint it blue then put on some of the plastic frame protectors. Check it once in awhile to make sure it's not rusting under the frame protectors and you'll be good to go.
