Jetting with new RS-2
I recently bought a TT 39mm FCR-MX and just picked up a new RS-2 full exhaust. The insert measures 1 5/16", certainally not the small "pototoe" nor is it open. In 0 to 500 ft, should I jet with a 160 or split the difference with a 155 and jet it at 158 ??
yosh only makes 1 insert.take it out and look at it.it is the potatoe.the oepning of it is much bigger than the insert itself.
155 main jet.
Thanks Eddie,
I just took the insert out and it maintains itself a 1 5/16" diameter throughout with out any necking down within the screen or exit to the tip. Did Yosh come out with a new insert for the RS-2 ???
I will post a picture tonight, however mine doesn't look like this at all. The screen stays the same diameter as the larger exhaust tip.
Hi Eddie.
I have one of these in my Ti system,do you loose much power with it left in?
Eddie, As I mentioned the inside diameter maintains at 1 5/16" throughtout. The insert does provide some sound attenuation. The device does not neck down as the one in your picture. Jetting ?
Thanks
Brad
that is just a spark arrestor.it is bigger r and doesnt have the perforated tube inside it.
i say split the difference.158.
