KX100 clutch Question
On this '05 KX100, I just replaced the clutch because I thought it was worn out. If you pull it in when it is running, it acts normal, no big drag on the bike or anything. If you pull it in when it isn't running, you can't push it without the rear wheel trying to turn. It'll slide on dirt unless I push down on the seat, and it pushes really hard. None of my 4-strokes have been like that. I replaced it with a new DP clutch kit and it's the same :applause:. Is this normal ??? The old clutch still looked new :applause:
My KX100 does the same thing. Works fine when running so I guess it's normal.
I guess I"ll consider it normal then :applause: . Too bad I spent over $100 on a whole DP clutch kit for no good reason :applause: . At least it is an upgrade, my son said he likes it much better than the stock one. Must be a prety big difference, see how he's only ridden it 3 times before!
